Booting in a res lower than Native
Solved by Tomasu,
Try also seeing if you can update the "drivers" for your monitor. The settings will only show you resolutions that the Monitor and GPU /both/ report they support. Sometimes the EDID information coming back from monitors is just wrong, and it can depend on the silly little .inf driver info that windows picks for your monitor.
Featured Topics
ItsHunterM8 ·
Posted in Troubleshooting0 -
1
3
2
2
Worstcaster ·
Posted in Peripherals2 -
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
