Do it yourself.
https://mainframecustom.com/
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/519111-cable-mods/#findComment-6897286
Why does it cost so much to buy a psu and cable mods anyone got a cheap website for this or help.. thanks
The mods are well expensive, I bought extensions for roughly 1/2 the price of the pre modded psu cables
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/519111-cable-mods/#findComment-6897289
Do it yourself.
https://mainframecustoive seen a video on it being done but dont want to play about with the wires when i havent done it before
If you've never done it before, how will you ever do it?
It's not too difficult. It's more time consuming than anything.
But it does give you more control over the length of your cables rather than having predefined lengths to choose from.
https://linustechtips.com/topic/519111-cable-mods/#findComment-6897318
Sleeved cables like from cable mods or other places aren't exactly what I would call expensive especially since you need to tools and time to do the sleeving, Extension are a good alternative or middle ground between costs and looks.
For pinouts and things you need to map them out to make sure you don't mix them up or get the connections wrong, if your interested under Sleeving and PSU pinouts and Diagrams has most of this info:
http://linustechtips.com/main/forum/14-case-modding-and-other-mods/
https://linustechtips.com/topic/519111-cable-mods/#findComment-6897330
