http://pcpartpicker.com/p/zWCkxr this is the build I am planning on building what cpu cooler should I put in it???
212 evo or dark rock
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/518239-cooling/#findComment-6887862
Depends if you wanna do overclocking or not, if not, a 212 evo would be plenty, if not any good AIO would be nice to have.
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/518239-cooling/#findComment-6887868
I plan on overclocking but a 2121 evo wont fit in my case so...
H100i or x61 Kraken.
CPU: Intel Xeon E3 1231 V3 3.4ghz CPU COOLER: Cryorig H7 w/ Red Corsair SP120mm  MOBO: MSI SLI Krait Edition Z170 MEMORY: G.Skill Ripjaws 8gb (2x4) Storage: Kingston V300 120gb, WD 1TB GPU: MSI R9 390X CASE: Phantom 410 (ew) PSU: Thermaltake Toughpower Modular 550w CASE FANS: 4 CORSAIR SP120mm MONITOR: LG 25UM67 KEYBOARD: Das4 Ultimate Cherry MX Blue MOUSE: Deathadder Chroma Left-Handed AUDIO: Sennheiser HD598 Black, Astro A40s
https://linustechtips.com/topic/518239-cooling/#findComment-6887911
Ah, then I'd recommend the H80i or something of the likes and a K series cpu.
Power supplies:
https://linustechtips.com/topic/518239-cooling/#findComment-6887917
I'd go with a Cryorig H7 if you live somewhere that they're available. Or a Noctua NH-D9L.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/518239-cooling/#findComment-6889035
