Moved to Cases and Power Supplies.
https://linustechtips.com/topic/518134-psu-help/#findComment-6886864
That's the new fully modular unit from Enhance. It should be a solid unit, as it's seem to be based on the same platform as the semi-modular version. However, since it's a new entry, it's a bit expensive. I would look at something. The aforementioned G2 series or the GS are a good choice for $100 and under
https://linustechtips.com/topic/518134-psu-help/#findComment-6886946
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438054
Edit: @above: yes, that's the one he was talking about.
yes they are both G2`s
to game or not to game, that`s the question
https://linustechtips.com/topic/518134-psu-help/#findComment-6886957
