Need help deciding for a GTX980Ti
Hey guys,
so I am looking towards getting 2 new GPU's meaning I would like to SLI 2 GTX 980Ti's. Now here comes my question:
Because there are sooooo many diffrent varients of the GTX 980TI out there I do not know which once to look at.
Space wise I should have the space in my case for all of them in a SLI configuration. Case is: Phanteks Enthoo Primo.
Hope you guys can help me out, also would a 1000W PSu from EVEGA, more specific the EVGA SuperNova G2 1000W be enough for SLI configuration so it doesnt botleneck them. I have a i7-5930k CPU which has a power consumption of about 340 iwht the OC and under load, which would mean the GPU's cannot have more then 660W meaning 330W per GPU. And I saw some of them get a power comsumption up to 480 if overclocked and under load.
Another Question what I would have is how hot should the GPU run max? If I am right one of the GPU's gets alot hotter in a SLI configuration because space limitation between them.
Nice Greets RockiLocky
EVGA GTX 980Ti FTW ACX 2.0
1000W is plenty.
