so i built my new pc and finaly i will be instaling my new gpu so i want to ask if you like it
so i have a cx430 and an i5 4460
and im on a buget so i picked msi gtx 750 ti twin froz 2GB
from what i have seen it will easily play 1080p. on high-ultra in most games.
What are your opinions on this????
https://linustechtips.com/topic/517981-help-a-newbie/
It's fine but I would upgrade the PSU before the GPU.
High-Ultra won't be happening with a 750 Ti
Low-Medium yes.
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885236
Not ultra, but very high at 30FPS
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885237
Not even high. Witcher 3 low settings 45fps
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885243
Depends on what he plays. Witcher 3? you will not get high or medium true, but if he is playing games like Borderlands 2, GS:GO, WoW, League of Legends, Tomb Raider 2013, Just Cause 2. Medium - High is perfectly fine,
Just make sure he installs Geforce Experience to get the optimized settings. :)
i7-6700k OC'd 4.5Ghz, Noctua NH-D15, EVGA GEFORCE GTX 1070 SC
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885264
https://m.youtube.com/watch?v=Ev7yfNw0g30
on this video around at 1:50 you can see how it goes on fallout 4 high-ultra
All i see is 30fps peasantry in a badly optimized game on an aging engine
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885268
GFE is godawful. It pushes my shadows down and adds AA. Fuck that crap.
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885269
Get a new PSU before you upgrade. The CX series works fine and all but its not really ment for gaming rigs and 430 watts is kinda low if you ever want to upgrade in the future.
Join da discord
(Intel Core i5 4590 - XFX R9 280 - ASUS z97-A USB 3.1 - EVGA SuperNOVA 750B - 16GB EVGA DDR3-EDITION - NZXT H440 -
WD BLACK 1TB - OZC ARC 100 240gb)
#locked(ง ͠° ͟ل͜ ͡°)ง
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885271
+1 on that, personal tweaks are always better than automatic.
4Xmsaa is enough for most people to not notice.
I have never and will never use AA
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885288
For me it has done wonderful. Maxing out my shadows and AA in most games and running it fine. If my hardware isn't able to support it then it lowers both.
It's different for each person. I would say for him to give it a try and see if he likes it himself before discreditting it. I used to use Razer Cortex to "Boost" my games and it did fine until I learned how to just do in and disable processes and manage my hardware better.
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885290
if not then what gpu you would buy max buget 160E keep in ming the cx 430
Nothing better. With the CX430 you locked yourself to the 750 Ti
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885301
really?
Any reason for this?
I find edge even worse than low framerates.
rather go msaa4 30 than no AA 60
Fuck AA
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885305
Plays Shadow of Mordor med/high 50 minimum, max 80FPS
OP please get a R9 270/x. They go pretty cheap, so do GTX 950s. Much worth the extra $10-$20
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885315
Not really.. It just takes good airflow.
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885322
Still a gamble. This is a CX430, not CX500 or CX600. He'll be pushing it at 70% load with a 270X
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885329
He could also have a 3rd to 4th revision of theCX series
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885337
Still pushing it past 70% load on a PSU that doesn't like even 50% load
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885361
i got a bit lost isnt an r9 270x power hungry ??
If you had a half-decent PSU you could run a R9 390 off of it.
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885362
You are honestly making it sound like the CX430 is worse then that cheap Chinese HP PSU I had in my rig before.
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885384
Both are crappy as fuck.
https://linustechtips.com/topic/517981-help-a-newbie/#findComment-6885394
