Is there any way to change the fan speeds in the ASUS bios? It seems that I can only ignore fan speed,set minimum speeds and fan profile. No actual curve that I can change. I'm using a M5A99FX PRO R2.0.
This is the BIOS I'm looking at.
AMD FX8350 Black OC 4.5ghz--NZXT Kraken X31--ASUS M5A99FX PRO R2.0--MSI R9 380 4G--Corsair RM750--Corsair 16GB Vengeance
Logitech G300--Roccat ISKU FX--Logitech Z623--HyperX Cloud II
https://linustechtips.com/topic/516505-bios-fan-control/
you need to go to advanced mode and look for q-fan control in the tabs at the top
https://linustechtips.com/topic/516505-bios-fan-control/#findComment-6868025
Yes, found it but then I only see the Q-fan, Low limit and fan setting (performance, silent, normal).
https://linustechtips.com/topic/516505-bios-fan-control/#findComment-6868071
can you take a pic or find an image on google of what youre looking at?
https://linustechtips.com/topic/516505-bios-fan-control/#findComment-6868084
Found on the internet.
https://linustechtips.com/topic/516505-bios-fan-control/#findComment-6868093
ok that looks like the older asus UEFI, the new one has the option to change fan curves
so if you want to set custom fan curves for your fans you need to do it from within your OS using thermal radar and AI suite (comes on the motherboard CD)
from the UEFI you will only be able to change the default options like normal or performance :(
https://linustechtips.com/topic/516505-bios-fan-control/#findComment-6868112
Crap! Well I have an aerocool touch 2000 fan control wich is shit. Any way to upgrade the bios?
https://linustechtips.com/topic/516505-bios-fan-control/#findComment-6868305
i dont think so, i think its just a feature on the newer asus boards...
thermal radar is not bad though, i used that for almost 5 years and it worked nicely
https://linustechtips.com/topic/516505-bios-fan-control/#findComment-6868404
