Hello, I need to choose fans for my 240 radiator
but the Noctua's fans are too expensive for my opinion(and I don't like the brown model)
So I thought about Corsair SP120 Performance Edition but I'm afraid it will be too loud
Someone who has these can tell me if it too loud?
https://linustechtips.com/topic/516501-fans/
there loud.. the quiet editions (derr) arent tho
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/516501-fans/#findComment-6867915
Noctua redux fans are cheaper and grey.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/516501-fans/#findComment-6867919
Yes they are loud! I have two of them and they are louder than my three AF series combined.
AMD FX8350 Black OC 4.5ghz--NZXT Kraken X31--ASUS M5A99FX PRO R2.0--MSI R9 380 4G--Corsair RM750--Corsair 16GB Vengeance
Logitech G300--Roccat ISKU FX--Logitech Z623--HyperX Cloud II
https://linustechtips.com/topic/516501-fans/#findComment-6867921
As mentioned above; they make a more quiet optimized variant as well.
https://linustechtips.com/topic/516501-fans/#findComment-6867930
for this radiator: EK-CoolStream 240 PE(thickness: 38mm, FPI:38(19 split fin))
how much RPM will give the best performance?
the most rpm possible, but they will be louder and it will only get you a few degrees better cooling
"God created war so that Americans would learn geography"
https://linustechtips.com/topic/516501-fans/#findComment-6867960
Mate spend money on them or don't bother at all!
Having had corsair fans in the past, they are more for looks then performance.
Here is a solution, pure performance and inaudible sound (BeQuiet SilentWings 2) (airflow fan) and for (static fans) Noctua NF-F12 Industrial 2000RPM.
Get these and you won't ever look back.
Might add this later...
https://linustechtips.com/topic/516501-fans/#findComment-6867961
Someone who have Nocta NF-F12 Industrial sait to me that they are loud
https://linustechtips.com/topic/516501-fans/#findComment-6869748
I Have them and they are pretty much silent if you have them under PWM control. I've been through about 6 differentness companies, and this is by far the best combination for airflow/static silent/performance.
https://linustechtips.com/topic/516501-fans/#findComment-6873168
Venturi HP-12 are top tier fans at about 1/2-2/3 of the price of noctua fans.
And they are all black.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/516501-fans/#findComment-6873289
