hi i have 2 970 in sli...
the nvidia controll pannel says i have to connect the sli bridge for better performance... i already connectet the sli bridge and set the settings to maximum power...
my board is sli capable its the asrock z97 killer and  now i dont know what to do... 1 card is fully occupied at 1404mhz boost clock and the other one is sitting at 135mhz clock..
pls help...
https://linustechtips.com/topic/515845-help-sli-isnt-working/
Flip the cards around (so move the one at the top to the 2nd slot, and the one at the bottom to the 1st slot), and make sure that the sli cable is seated properly?
Also check which slots the cards are in, because if you put the 2nd card in the bottom most slot, it will be running at 4x speeds, which wont work.
Edit: try setting the physx setting to auto.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/515845-help-sli-isnt-working/#findComment-6860706
Are the PCI slots set up correctly in the bios?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/515845-help-sli-isnt-working/#findComment-6860709
ok then pls wait a minute i´ll try this
https://linustechtips.com/topic/515845-help-sli-isnt-working/#findComment-6860731
there maybe some settings related to port configuration and PCI gen type, just check none are disabled.
Also try the card on its own make sure it isnt a doa
Ryzen Ram Guide
https://linustechtips.com/topic/515845-help-sli-isnt-working/#findComment-6860866
dead on arrival, unless you know both cards work
Ryzen Ram Guide
https://linustechtips.com/topic/515845-help-sli-isnt-working/#findComment-6860882
what motherboard is it? check the bios settings
Ryzen Ram Guide
https://linustechtips.com/topic/515845-help-sli-isnt-working/#findComment-6860897
do you have a different bridge you can try? PCI power in both cards?
Ryzen Ram Guide
https://linustechtips.com/topic/515845-help-sli-isnt-working/#findComment-6860941
try the other one see if it works
Ryzen Ram Guide
https://linustechtips.com/topic/515845-help-sli-isnt-working/#findComment-6860975
pls help me  :(
https://linustechtips.com/topic/515845-help-sli-isnt-working/#findComment-6861049
pls help me  :(
Drivers can be a large part of weird issues like this, because once my friend was testing a nvidia card on his amd system, and after he was done, the nvidia drivers conflicted somehow stopping the PC from booting.
Download the latest driver from nvidia, and check the box "perform clean installation" during the install.
https://linustechtips.com/topic/515845-help-sli-isnt-working/#findComment-6861177
btw. how did u configure ur sli setup? @stealth80
I added the second card to the slot after the waterblock,water bridge and connected the SLI bridge to the connections closest to the back of the case. Loaded windows > NVidia panel > max performance and it worked
Ryzen Ram Guide
https://linustechtips.com/topic/515845-help-sli-isnt-working/#findComment-6861311
