Wide angle lens for mirrorless
Solved by ALwin,
These are your options if you want a native E-mount lens.
Additionally you can use a lens mount adapter and use wide angle lenses from Sigma, Canon, Nikon. And if you use a Metabones Speedbooster adapter with a corrective optical element you can virtually get the same FOV of a lens mounted on a 35mm camera.
