My family has all gone in on a walmart card for me for my birthday. I found some video cards on walmart's site and I was  trying to decide if I should upgrade. I have a asus tuff 1650 4gb card. Its not that it doesn't run well or well enough for most things. I want to future proof a little bit to help with things. I don't play a ton of video games, some pc games, but nothing like cyberpunk or anything. Minecraft and the halo series are probably the roughest things I do with it, game wise. I do some video editing and wouldn't mind getting things out faster.
I'm not fully sure if I'm understanding how bottlenecking works, but I think the 1650 is bottlenecking the rest of my system.
I5 12600kf
32gb 3200 ddr3
Mid sized tower case
I'm not set on radeons, but I thought I'd give it a chance since I've always done nvidia stuff.
ASRock Challenger ITX Radeon RX 6600 XT 8GB GDDR6
ASUS Dual Radeon RX 7600 V2 OC Edition 8GB
PowerColor Fighter Radeon RX 7600 XT 16GB
My eyes are pretty bad and so I keep the resolution at 720p. I don't need a power house, just enough to make sure I'm good for a while.
Any help, or other suggestions would be great, thanks.
https://linustechtips.com/topic/1573900-need-help-deciding-please-help/
I5 12600kf
32gb 3200 ddr3
If there are any a 6700XT or 6750Xt can often be a great price-performance choice for amd GPUs
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
As a 6700 XT user, I agree. The 7600 XT also offers almost identical performance and can be found for relatively cheap prices.
hi
30 minutes ago, Idiotic_idiot said:
So something like This?
Thats a 7600, so a bit of a downgrade from the 7600XT, and the 3060 is a decent downgrade again
If the 7600 is a base level of 100% youll get about 120-130% from the 6750XT and about 70-80% from the 3060
so if the 7600 gets ~80 frames, you can expect ~100 frames from the 6750XT and ~60 frames from the 3060 (very rough numbers and subject to change depending on the game/programme)
That is, dependant on VRAM as the 7600 (non XT) has 8gb of VRAM, which can easily be filled with more recent games. Id recommend something with at least 12gb going forward
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
I5 12600kf
32gb 3200 ddr3
Never buy something because it'll be good later, if you don't need it now.   Future proofing , which isn't a thing, when your current GPU performs as you need, is wasteful.
Now, even if your eyes are bad, get glasses? Mine are as well and i don't understand staying at 720p for that reason.   You may not have used all the words needed to explain it.
Now the 1650 4gb is a weak card, for 1080p which you should be playing at minimum on modern monitors.  Native resolution is clearer anyway, so running 720 can be less clear and be more work for your already problematic eyes to focus on, as they constantly try to.
All that said, what is your gift card balance?  Seems like $200-250?
Also, you may not play more intensive games now, but when you have the system that CAN... You will expand your game library.  So yes, splurge on the most powerful GPU you can afford.  We just hit my sons gf a new machine and allshe talked about was finally playing Stardew Valley.  He bought her Baldurs Gate 3 and she's addicted 👍
So enjoy your machine!  And life!
Yes, I had 2 cups of coffee already this morning.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
I'm pretty much just repeating what @TatamiMattsaid, but this is the non-XT version, which is a pretty significant downgrade, and the 3060 might be cheaper but that's another downgrade.
I would just get a 6700 XT, I got mine brand-new for $250 (i don't think they even sell them anymore brand-new but you can find them for around $250 used.)
The 6700 XT is similar to an RTX 3070, a pretty big upgrade over a 3060 or 7600 non-XT.
If you want to save more money and don't need a card that's capable of 1440p (3070 and 6700 XT are considered 1440p cards) then a 6600 XT or 3060 are good options if you can get them for very cheap. (The 3060 you linked is pretty expensive. If you do decide to go towards the "budget end," the 6600 XT is a much better buy over the 3060.) They'll perform good at 1080p.
hi
32 minutes ago, Idiotic_idiot said:
Okay, I've read through the comments
Is the $100 difference between the 6600xt and the  7600xt worth it?
The two compared to each other?  No.
But as part of a while PC?  Yes.
The 7600xt isn't 50% better, but in a $900 vs $1000 PC, it is.
Just too much info, but yes get the best you can afford.
OnePlus Ecosystem:
3D Printing:
I5 12600kf
32gb 3200 ddr3
For 720p gaming, you do not need a gpu as good as the 6600xt, 6700xt, and the 7600xt. If you don't care about going last gen, the 5700xt will fulfill all your needs
