Front headphone jack not working
Go to solution Solved by W-L,
I plugged in the HD audio to the port and I cut off the AC97 port, It worked for a while but doesn't now, do I need to wrap the AC97 wires in electrical tape? Or what?
-Thanks in advance
It should work if the HD audio is properly connected, make sure the old wires from the AC97 aren't shorting each other out in any way.
I think you have to solder it, I may be wrong the electrical tape is worth a shot.
Ariana Grande's Leaked Nudes!!!111!11!
Ayyyyyy
Gaming Rig:     CPU:  i5-4690k  Cooler:  H80i  Mobo:  MSI z97 PC MATE  RAM:  16gb Fury White  Storage:  1TB WD + 120gb Fury SSD  GPU:  GTX 970  Case:  NZXT S340  PSU:  NEX 650W  Keyboard:  K65 RGB  Mouse:  Mionix Naos 7000  Headphones:  ATH-M50x  Monitor:  2x VN248h-P + 1x MG248q  Setup Photo:  (To come)
-Thanks in advance
