Hello there,
thank you for checking out my topic about my latest update of my main PC. I have been working this machine with my Corsair 900D case, since it was build in April 2015. At the time I built it, it was just meant for pure performance and OCing. Of course I always make sure, that when I´m just building for performance, it also looks okay, but looks were just a second thought. Now I´m reworking this machine to make it a lot more beautiful and pretty, and I really wanted to go back to hard tubing and other nice features. My hardware in this PC is used for rendering, compressing, editing, benchmarking and gaming of course. I have been working with custom watercooling for a very long time already and so I have all the necessary experience to make this something special.
I will update this thread, as I´m advancing in the progress of reworking the computer, with pictures and probably also a VLOG with some building guides if I find the time to do so. I´ve never had too many specific names for my PCs, so I just called it the Big Boy since the 900D is such a massive case. Unfortunately the 900D saw already 4 or 5 builds and so all the modding and working on and with it left their marks, so it became time for something new :).
You can leave me a comment about your thoughts and/or subscribe to the topic that you´ll stay updated whenever I have something new to post :).
Update #1 Modding the SLI bridge
Update #2 D5 Pump mod
Update #3 Fullcover Block on the Mobo
Update #4 Testing the new home
Update #5 Modding the Corsair 600C
Update #6 Tools and Bending the PETG Tubes
Update #7 Installing the RGB Lighting
Update #8 Testing the loop
Update #9 Cables and Cable Management
Update #10 Color matching
Update #11 Filling the Loop
Update #12 THE FINAL PC & LOOK
Let´s get started, shall we? This is how my whole setup used to look (December 28th 2015).
Setup Specs:
Chair - DX Racer
Mic - BLUE Snowball ICE
Headset - Corsair H2100
Monitor1 - Acer XB280HK Predator 4K G-Sync (3840x2160) [Yeah I know I´m a star wars fan ;) ]
Monitor2 - Asus PB278Q (2560x1440)
Keyboard - Racer Blackwidow Chroma
Mouse - Razer Taipan
That was the version of my 'Big Boy' before the upgrade.
System Specs:
CPU - Intel i7 5960X
Mainboard - AS Rock OC Formula X99
RAM - G.Skill Ripjaws 2400MHz CL14
GPU - nVidia Titan X 2way SLI (original nVidia 2way SLI bridge)
OS Drive - Samsung 950 PRO M.2
Game Drive - Samsung 850 PRO
Cache Drive - WD Blue 2TB
PSU - EVGA 1200 P2
CASE - Corsair 900D Obsidian
CPU Cooler - EK Supremacy
GPU Cooler - EK Titan X fullcover + backplate
Pump - D5 Swiftech MCP655 variable
Radiator - Phobya Extreme 1080 + 4x 180mm high static pressure fans (Silverstone FT02)
Reservoir - 2 250mm reservoirs
Softtubing - XSPC 3/4 OD 1/2 ID
Compression Fittings - EKWB Gold
The new Corsair 600C is for my needs prefect, that´s why I was sold on it the moment I layed my eyes on it. I almost pulled the trigger for a Caselabs, but with the right modding this Corsair 600C will offer me everything I want and need. Now I´m trying to fit all in here:
There are lots of parts I´ve just bought, and I can´t wait to put it together:
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/515458-big-boy-build-finished/
Don't drop your CPU down the stairs... :P
Nice collection of parts and lovely case c: (it even has an attic).
Knock on wood that this one lives longer than the first 5960X I´ve had hehe ;).
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6856628
@Najuno Whats the table you have for your 900D?
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6857558
That is just two black coffee tables from Walmart put together hehe. I´ve been looking around for a good height because the 900D was so tall. I´m not sure this still works with the 600C.
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6868479
I'm loving the green and black color scheme, I'll never get tired of seeing them if they are done right.
Are you going to be using har line tubing, anyways nice rig and another day for me to complain about not having a pc :(
Yes this time I´ll be going back to hard tubing. I will use EK HD PETG 12/16mm. There are more pictures about to come soon :).
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6868633
Those are going to be some large radius bends with that tubing bit it should fill in the space nicely ( ͡° ͜ʖ ͡°)
Well that´s true but I don´t have a radiator in the case, so I´ve got plenty of space hehe.
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6875252
UPDATE #1
Alright here is some little update. Took the nVidia SLI bridge apart that I could paint it yellow since the original color was a bit boring and not a good fit.
I like the result :).
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6875311
My thought on going from the 900D to the 600C is why waste such a badass case that can last for an incredibly long time because you can do so much in the 900D. I personally own one for my first build that will definitely come around the summer after my next semester.
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6875377
My 900D was a good buy and a good choice, but if you read my initial post you´ll find out that I´ve had 4 or 5 builds in there, it´s just wear and tear. I don´t keep my hardware very long usually with every new gen I build a new PC. And it was just time for new ideas.
And even though a 900D is a nice case it is far from being perfect.
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6875418
My 900D was a good buy and a good choice, but if ou read my initial post you´ll find out that I´ve had 4 or 5 builds in there, it´s jus wear and tear. I don´t keep my hardware very long usually with every new gen I build a new PC. And it was just time for new ideas.
Oh okay that makes sense. If you're going for high-end hardware like the highest-end Asus ROG motherboards like the Rampage V Extreme or the Maximus VIII Extreme, Titan X's, 980 Ti's, Titan, and Titan Blacks, I would much rather squeeze as much life out of those as I can with or without overclocking (preferably with overclocking) rather than upgrade them on an annual basis. You will be able to get maximum return if you do that because personally I would. That doesn't mean don't go for those types of components. I'm all for enthusiast builds and I am a PC enthusiast. Don't get me wrong on that one. My first system for the tower alone is budgeted out at USD ~$3,200 for my gaming and college needs. I do computer animation and modeling and I'm going to do Photoshop this coming semester.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6875450
So many parts that want to be assembled :).
This Bitspower D5 mod kit is very nicely built. I just hope the Bitspower Fullcover Block for my mainboard especially the CPU cooler is as good as my EK Supremacy was.
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6878478
Alright time for UPDATE #2 D5 Pump modding.
I really hope that everything is sealed up and tight otherwise this is going to be a mess ;).
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6880408
Happy new year to all of you :).
This is Update #3 Installing the Bitspower THOR fullcover waterblock on the AS Rock X99 OC Formula (CPU and M.2 are already on the board).
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6885167
I just wanted to see how much space I will have to work with. Thank god this build does not require any internal fans :).
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6886870
@Najuno I think some RAM blocks would look sweet.
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6889421
I thought about it, but I was afraid it would make the build in the comparable small case too bulky because all you´d see then is a big covered up surface, I didn´t like that idea. So instead of cooling RAM, what makes little to no sense I decided to go for the fullcover THOR because cooling the VRM is a good thing, when you don´t have a fan in the case :).
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6889450
Hmm. You should have bought a SOC Champion instead. Why did you pick the AsRock?
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6889470
Because the SoC Champion wasn´t available at that time, and I´ve read too many bad things about it, it seems there are lots of people having issues with their RAM banks and compatibility. I´ve ditched an Asus X99 Deluxe and a Rampage V Extreme before the AS Rock OC Formula due to the crappy state both boards were in. I kept the X99 Deluxe because after many UEFI updates it was stable enough to fit a 5820K and mild OCs, but it crashed all the time with XMP settings and the R5E was even worse, that had not only these issues but also failing USB ports, it was a nightmare. I thought in the first place that it was the IMC of my CPU but I´ve tested a 5930K and a 5960X with it and both of these CPUs worked perfect on the AS Rock OC Formula.
The funny or scary part is, that I need less Voltage for the same OCs with the AS Rock board. Asus can go to hell with their X99 boards... I´m beyond disappointed TBH. As you can understand after such a hassle all you want is a nice stable and good mainboard.
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6889558
Yeah ASUS has really gone downhill. If that X99 Deluxe ever breaks, good luck getting a RMA
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6889616
Honestly if that would break right now I´d not even bother to RMA it. I´d open the trash can and there it goes then and order something hassle free. Now don´t get me wrong I have no idea how good or bad Asus is in Z170 chipsets, but X99 was a disaster.
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6889655
Not just X99, but ASUS have gone downhill recently. After Z77 mainly
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6889680
That´s very sad, I´ve held loyalty to Asus for so many years, you just couldn´t do anything wrong by buying it...
https://linustechtips.com/topic/515458-big-boy-build-finished/#findComment-6889696
