So in the new year I'll be building a new pc Based around these components:
i5 6600K
GTX 960
I have spent hours trying to work out what motherboard to go with....
Can anyone recommend a good mobo for overclocking and with some decent features and protection?
Ryzen 9 7900X
Asrock X670E PG Lightning
32GB G.Skill 6000mhz DDR5
1TB Samsung 990 Pro
Rdna 2 iGPU
https://linustechtips.com/topic/515255-skylake-build-help/
i5 6600K
GTX 960
Asus Z170-A for mid budget or MSI PC MATE for low budget.  If you're willing to pay for something like an MSI Z170 Gaming M7, get a cheaper Z170 motherboard and change the GPU to an R9 390.  At least change the 960 to an R9 380.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6853946
So unbalanced i would go with a locked i5 and a 970/390
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6853957
i5 4690K + Z97 is better value since you can re-use your DDR3 RAM
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6853958
i5 6600K
GTX 960
that unbalance doe
if thats what you can afford then go with a locked i5 and a better gpu like 970 or 390
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6853984
that unbalance doe
I've watched many videos and read so many reviews on the gtx960 being paired with the i5 6600k and it seems to preform pretty damn good
Ryzen 9 7900X
1TB Samsung 990 Pro
Rdna 2 iGPU
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6853998
yeah
but you can get alot better performance with a 390 or gtx 970...
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6854005
The GTX960 seems to be doing fine for me on the games I play at 1080p....
ok a fiat may be enough for road driving but an audi is better,
would you pick the audi or fiat?
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6854015
i5 6600K
GTX 960
i5 6600k
MSI Z170 Krait motherboard
R9 390.
or just get a Z97 build to save cash.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6854020
yeah but there's more performance offered by an R9 390..... or even a R9 380.
Old Rig
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6854032
yeah
The 960 would be in the build for no more than a year at most before it gets swapped out for a better card but right now i'm more bothered about changing my x4 860k rig
Ryzen 9 7900X
1TB Samsung 990 Pro
Rdna 2 iGPU
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6854037
Yea, I'd choose fiat. For fuel efficiency. lol sorry man, jk. haha.
I'd go for R9 390 for the better @OP
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6854041
But R9 390 is already a better card. You can have this card like for 3-4 years.
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6854046
If you are using a GTX 960, You are not utilizing the i5 6600k. Just save your money and get practically the same exact performance. i5 4690 FTW
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/515255-skylake-build-help/#findComment-6854054
