well so do it, although could you show me your power button cable because I have a feeling it is shorting on your case or something. If you have lights then it could be them shorting it. there is a host of ways it could happen.
IT Manager working in the Education sector.
https://linustechtips.com/topic/515019-pc-issue-help/page/2/#findComment-6851537
If I plug it out, how do I plug it back in? Should I take a picture of the button for you?
Core i5 4690k @ 3.8 GHz |  Hyperx Fury 8gb ddr3 1600mhz  |  GIGABYTE Z97-MX Gaming-5  |  Cooler Master Hyper T4  |  XFX R9 390 8gb  |  Corsair CX750M  |  NZXT H440 Black & Blue  |  Samsung 850 EVO 240gb  |  WD BLUE 1TB  |  ASUS VG248QE 144hz & ASUS VX238H
https://linustechtips.com/topic/515019-pc-issue-help/page/2/#findComment-6851551
no, take a photo of the button plug connected to the motherboard please.
Oh, connected to the motherboard? I thought you meant the button on the case, to plug that out. Well, the picture will be taken in just a moment.
https://linustechtips.com/topic/515019-pc-issue-help/page/2/#findComment-6851610
post-292167-0-89297800-1451314530_thumb.
post-292167-0-66560300-1451314560_thumb.
https://linustechtips.com/topic/515019-pc-issue-help/page/2/#findComment-6851643
https://linustechtips.com/topic/515019-pc-issue-help/page/2/#findComment-6851723
Wake up, please
https://linustechtips.com/topic/515019-pc-issue-help/page/2/#findComment-6851894
Sorry, I went for a bike ride. Anyway, it looks like it is normal to me. Do you have any lights to brighten up you case?
Only the case LEDs.
https://linustechtips.com/topic/515019-pc-issue-help/page/2/#findComment-6853219
Are you telling me you're plugging stuff in whilst it's on?
 Shouldn't matter, all USB peripherals are hot pluggable.
What can happen is USB drivers don't load right away so Keyboard has to be PS/2 which requires a full power down boot if plugged in before it is recognised. But as most peripherals are USB these days there should be no issue plugging things in
Aside :-
I was having all sorts of booting issues as I'd left an MP3 player plugged in (system tried to boot from it [the system had 'seen' a file system]).  Removed it, normal boot, then plugged it in again all was fine.
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
https://linustechtips.com/topic/515019-pc-issue-help/page/2/#findComment-6853303
Aside :-
You were the first person to misinterpret my nooby phrases. I meant plugging fans and hard drives into the psu, and it is labeled "Peripherals" on the psu of where you plug it in, so that is what I call it.
https://linustechtips.com/topic/515019-pc-issue-help/page/2/#findComment-6855324
ummm, do you have them turned on already when you start up your pc or do you turn them on after.
So, I brought it to MicroCenter and theyare diagnosing it.
https://linustechtips.com/topic/515019-pc-issue-help/page/2/#findComment-6855332
