Hi everyone :)
As mentioned in another post I am now building a new Pc and because of that I got a question about Memory. What does CL stand for and in which way does it separate itself from MHz? And is it better to have high/low Cl rating or High/low Memory MHz?
I appreciate any answer and thank you for all replies :)
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/51454-memory-cl-and-mhz/
CL is Cas Latency and it's basically the time that it takes to respond, the lower the better and CL9 is fine for gaming. MHz is the frequency of the RAM, the faster is usually better but you won't really notice it over 1600Mhz.
https://linustechtips.com/topic/51454-memory-cl-and-mhz/#findComment-687109
Thank you for a informative and quick introduction Samdb. But here is another thing: What is best to have? Low latency or High frequency?
Tor
https://linustechtips.com/topic/51454-memory-cl-and-mhz/#findComment-687116
Linus is talking a bit bout Shopping guide of RAM
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
https://linustechtips.com/topic/51454-memory-cl-and-mhz/#findComment-687157
Was looking for it but could not find yesterday but thanks :) I will be checking it out  :)
Tor
https://linustechtips.com/topic/51454-memory-cl-and-mhz/#findComment-687168
I think "they" say that frequencies are better than CL for most things like gaming, if you have the choice between one step up in speed that'll help more than one step down in CL. "they" also say that for productivity, CL might come more into play.
However, "they" say a lot of things, so don't take my word for it :P
https://linustechtips.com/topic/51454-memory-cl-and-mhz/#findComment-687175
Okay last question. When you have four slots for Ram on your Motherboard is it then best to fill up all the slots with ram modules or does it make a difference? Thinking about the Asus Maximus V1 Formula :)
Tor
https://linustechtips.com/topic/51454-memory-cl-and-mhz/#findComment-687187
I've always wondered about this myself. Looking forward to Linus' video.
CoolerMaster CM 690 II Basic | Intel i7-2600 | CoolerMaster Hyper 212+ 2x Zotac GTX 1070 AMP! Edition
Asus P8Z77-V LK | 2 x 4GB Kingston HyperX DDR3 1600MHz CL9 | SeaSonic M12ii 850W 80+ Bronze Crucial M4 128GB
https://linustechtips.com/topic/51454-memory-cl-and-mhz/#findComment-687216
That mobo uses dual channel so get your ram in sets of 2, either 2 or 4 sticks.  Read the manual which slots to put them in, this does matter if you only get 2 sticks.
Thank you for the info :) But does it have any advantages to have 4 sticks or is there no difference at all?
Tor
https://linustechtips.com/topic/51454-memory-cl-and-mhz/#findComment-687261
In dual channel mobo having ie. 8gb as 2*4 or 4*2 , two sticks are bit better. But you won't be able to tell difference. To answer your earlier question about which latency and frequency, think about how much you want to spend on ram, what design on heat spreaders you prefer first. If you want to spend bit more, there are kits that have cl9 and 2133mhz. They are usually 30$ more expensive than 160mhz kits.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/51454-memory-cl-and-mhz/#findComment-687954
It balances out overall but it depends what you're doing. Somethings like lower latency and don't care for high frequency and vice versa. Something like heavy rendering would benefit from higher frequency over lower latency.
https://linustechtips.com/topic/51454-memory-cl-and-mhz/#findComment-689357
