Hello, I am currently building my bother a pc as a gift using my spare parts and i was wondering about P/S size.
There will be no overclocking on this system and the parts are:
z97x-gaming g1
4790k
2x R9 290x
8gb Ram
2x 850 Evo 250gb
2Tb Wd hdd
H100
6 Fans
I'm hoping i can get away with a 850w evga g2. Let me know if you think i should go with a 1000W to be safe.
PC: EVGA SR2, 2x Xeon X5690 @ 4.5, 48gb GSkill Trident @ 1810, 2x Evga gtx 980 TI Classy, 6x 850 evo 250gb RAID 0, 2x WD 4tb, Corsair 900D, Custom Loop with Cpus And mobo, 3x Asus VN279q
OTher : EVGA x58 Classified3, Xeon x5679 @ 4.2, 12gb kingston HyperX fury, 2x Evga GTX 670, Adata sp550 120gb, 2x WD 2tb, Corsair Graphite Series 230T, Cooler Master Hyper 212 EVO, Asus VG236H
https://linustechtips.com/topic/514524-power-supply-size-recommendations/
The 850G2 is more than enough. You could go a bit smaller if you'd like.
I wonder why you'd go with a Z97 board and K-sku cpu if you're not going to oc.
Moved to Cases and Power Supplies.
850 watts is more than enough for this system. :) I think even a 750 watt would suffice, and maybe even lower (but lower than 750 w would be cutting it close though). :)
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
I was using the 4790k and mobo in my pc while i was waiting for my evga sr2 come. That's why i have it sitting around.
