Help Picking Out PSU
Go to solution Solved by jimakos234,
Would a 650W PSU be able to handle everything at full load (including the future EVGA GTX 980ti Hybrid)?  I built my PC on PC part picker and everything did fit under 500W, however I didn't know if that was a simulated full load or not.  Doesn't the hybrid pull 250W at full load or did I misread something?
That whitelist makes things a lot easier.
it should be enough, but since you are getting a 980ti , i would get a 750w in order to OC both cpu/gpu, and if you plan to get a second one for sli, get a 850w unit and move on :)
also the g2/p2 units from evga have 10 years warranty, hard to miss that , and gs/ps from evga 7 years
seasonic and superflower units (most of them) have 5 year warranty, and others 7.
I plan on upgrading my current GPU to an EVGA GTX 980ti Hybrid and I would like to know what PSUs you all would recommend (or if I even need a new PSU).  I was looking at some of Corsair's 1,000W PSUs primarily because I am use to Corsair and their build quality.  I am open to all manufacturers of quality PSUs.  I would like for the price to be at or under 200 USD.  My current build is listed below.  What do you recommend?  FYI, I am a beginner at PC building and I do not know much about modular PSUs except that they are great for cable management.
  • Intel i7-4790K
  • Gigabyte GA-Z97-HD3
  • MSI GTX 970
  • Corsair 750D
  • 120GB SSD \ 2TB HDD
  • High Power 800W HPL-800BR-F14S
  • 2-ViewSonic VX2252MH
  • Corsair H80i
  • Razor Black Widow Chroma
  • Logitech G502
  • Turtle Beech Headset (Probably going to replace it also)
  • Windows 10
Legends never die.
https://linustechtips.com/topic/514413-help-picking-out-psu/
Is high power the model or the brand?
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/514413-help-picking-out-psu/#findComment-6845191
The brand, I've done a few internet searches on it and it is rated at 80+ and they sell a few different PSUs on Amazon, albeit with mixed reviews.
ok find any on the power supply list in my sig that you like and get it. 80+gold would be my recommendation.
https://linustechtips.com/topic/514413-help-picking-out-psu/#findComment-6845279
evga Gs/g2/Gq 650w should be enough
or seasonic G , xfx XTR, super flower leadex gold
corsair RMx or RMi, but they are overpriced, the other units mentioned before are better for the price
Legends never die.
https://linustechtips.com/topic/514413-help-picking-out-psu/#findComment-6845316
The site has changed....
https://linustechtips.com/topic/514413-help-picking-out-psu/#findComment-6845328
Thanks for the info, I plan on doing a little bit of case modding after I buy the GPU (mainly just get the NZXT Hue+ lighting system).  I think that I am going to go with the EVGA SuperNOVA 850 G2 80+ Gold.  This should give me a little wiggle room for some time and I do not plan on building a custom water loop so 1kW is probably overkill.
Legends never die.
https://linustechtips.com/topic/514413-help-picking-out-psu/#findComment-6845405
