Looking for a replacement cable
Lotus
It's a 4 channel (component?) to standard 3.5mm jacks, and it must be at least 6' in length. I have looked many different places, and so far all I've found is combining two different cables (a splitter and a long single cable) instead of a proper replacement cable. I really just want a replacement cable, and no I do not want to replace the headset because it sounds amazing and the microphone is the best headset microphone I've ever heard.
I honestly think that the splitter and long cable is an elegant enough solution.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
