I am planning on buying the bracket and installing it on only one of my cards for now, (http://www.scan.co.uk/products/corsair-hydro-series-hg10-n780-gpu-hydro-cooler-bracket-for-nvidia-geforce-gtx-770-780-780-ti-titan-) I know my GPU is supported but it only says Hydro series coolers can be put onto it. I have the corsair H60 which i am pretty sure is a hydro series cooler but i just want to double check if it would fit so if any of you guy know that would be great.
https://linustechtips.com/topic/513351-corsair-hydro-cooling-bracket/
