A pencil does the trick
Magical Pineapples
https://linustechtips.com/topic/512891-how-to-fix-gpu-sag/#findComment-6831587
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/512891-how-to-fix-gpu-sag/#findComment-6831605
This^
I always recommend it to ppl with this problem :D
https://linustechtips.com/topic/512891-how-to-fix-gpu-sag/#findComment-6831628
It's a good solution. Not available to everyone unfortunately.
Yeh ik :( Puget really isnt too big a company.
https://linustechtips.com/topic/512891-how-to-fix-gpu-sag/#findComment-6831652
Support it with a piece of straight dowelling, dyed black (pencils, permanent markers and bog roll tubes work too).
Run a bit of fishing line from the roof of the case and loop it around the cooler.
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
https://linustechtips.com/topic/512891-how-to-fix-gpu-sag/#findComment-6831921
I wanted to fix the sagging on my GPU and I know that it really won't cause any problems (unless it is really severe) it is just really annoying aesthetically annoying. So I was wondering if there was a nice, elegant solution or one that is not very visible. Thanks  :D
What gpu do you have and does it have  abackplate?
https://linustechtips.com/topic/512891-how-to-fix-gpu-sag/#findComment-6874541
