you mean you want to make a mod?
https://www.youtube.com/playlist?list=PLQPiZYWovwmnZlgvbHCbz6TefIgeEiVcj
Excellent tutorial by Pahimar :)
if you mean this^
then:
Does anyone have any advice on where to start? What are some good Forge tutorials?
do you know java, if not start by learning it on like:
https://www.codecademy.com/
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/512541-modding-minecraft/#findComment-6827913
I've already seen some of it, but I want something complete. Heard he stopped making tutorials a while ago.
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/512541-modding-minecraft/#findComment-6827914
what is not complete about it that you would like to learn?
The tutorial only covers the basics. I want to learn about more advanced stuff too.
https://linustechtips.com/topic/512541-modding-minecraft/#findComment-6827931
What do you mean by 'advanced stuff'?
Probably one of the most advanced things one can do with Minecraft is more of a hack type mod by way of using bytecode injection/manipulation. Forge provides some Excel sheets that translate some of the obfuscated code. One can use these to inject modifications client side at runtime. An example use case would be that of an XRay mod or full map visibility mod. You see, due to the fundamental architecture of the game the client is sent a complete picture of all of the data for a given chunk at once from the server - it's currently the only way it can work. One simply has to change the code that is loaded at runtime (bytecode manipulation) in order to do as they desire with this data.
Perhaps it might interest you to look that up as a next step.
Oh dear have I just given a monkey a machine gun? Silly me... :blush:
The single biggest problem in communication is the illusion that it has taken place.
https://linustechtips.com/topic/512541-modding-minecraft/#findComment-6852623
wow desents stuff , i remeer watching a mod vid that was 20 mins when he got to the middle he was like do the thing and then booooom the mod is made
https://linustechtips.com/topic/512541-modding-minecraft/#findComment-6868384
MrCrayfishes tutorial is great for getting started, it assumes you know java and just teaches you how to make items and blocks and just the basic stuff
Thanks I'll check it out.
https://linustechtips.com/topic/512541-modding-minecraft/#findComment-6874138
