Q6600 boot problem
Go to solution Solved by Master Disaster,
Sounds like a heat issue to me.
Boot into BIOS and leave it at the BIOS screen, does it still shutdown?
Hey guys, so I've upgraded from a Pentium D to a Q6600 on a GA-965G-DS3 rev 1.0 MB with 2x2gb of ddr2 800 and I have the latest bios the thing is that I see the post screen then the Windows is starting screen but then it just shuts down
Can anyone help?
Thanks
Any beep codes?
https://linustechtips.com/topic/511758-q6600-boot-problem/#findComment-6820384
Ok but what if I simply reinstall Windows
I wanted to reinstall anyway
But it should atleast try to show the Windows startup screen... Have you tried the CPU on another rig? Are all the power cables securely plugged it?
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/511758-q6600-boot-problem/#findComment-6820431
Main Rig:-
Server:-
https://linustechtips.com/topic/511758-q6600-boot-problem/#findComment-6820441
Gimme a sec and I try
Watch the temps while you're there ;)
Main Rig:-
Server:-
https://linustechtips.com/topic/511758-q6600-boot-problem/#findComment-6820446
I can't reapply my Intel heatsink
Have you tried staying what @Master Disaster suggested?
Echelon Mk 2.11
https://linustechtips.com/topic/511758-q6600-boot-problem/#findComment-6820535
I meant to open the hardware monitor in BIOS and watch the CPU temps to see if they go up to high :)
Main Rig:-
Server:-
https://linustechtips.com/topic/511758-q6600-boot-problem/#findComment-6820536
