-=[system Specs.]=-
Mobo.   L1N64-SLI WS
CPU      AMD Athalon 64 FX-74 (3.00GHz)
RAM     6GB DDR2
OS        Win7 Ult. 64-bit
PSU      Antec TruePower Quattro TPQ-850 watt \
Edit** Driver: High Definition Audio Device Ver, 6.1.7601.17514 By: Microsof
NOTE** Could not find any BIOS updates for my board
-=[Problem]=-
The problem is that when i try and play sounds through my computer they come out scrambled and distorted. However every now and then it will go back to normal. NOTE** I test my sound through the use of You-tube and the audio test in the "sound" portion of the control panel.
Things i have done:
1) Checked all my connections and that they are properly working.
2) Updated my drivers to the best of my abilities
NOTE** I have no idea which drive my computer is actually using
3) Restarted the computer in hopes of some miracle fix ;)
I am posting this here in hopes of getting some other opinions on what might be wrong
My system is not exactly a "normal" setup as it does not have a case and is constantly changing however this is the first time i have had sound problems with it.
Please Help
Sincerely,
Majere[Your Friendly Computer Geek]
https://linustechtips.com/topic/511679-win7-sound-issues/
-=[system Specs.]=-
Mobo.   L1N64-SLI WS
RAM     6GB DDR2
OS        Win7 Ult. 64-bit
-=[Problem]=-
Things i have done:
Please Help
Sincerely,
its using a soundmax chipset...those are notorious for scrambled audio
what driver version are you using?
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/511679-win7-sound-issues/#findComment-6819278
It supposedly using High Definition Audio Device Ver, 6.1.7601.17514 By: Microsoft
lol
you need to update that dummy
SoundMAX ADI1988
is the chipset
https://linustechtips.com/topic/511679-win7-sound-issues/#findComment-6819296
I was looking around for a newer one
doesn't look like theres anything newer then 6585
so hopefully that one works
looks like there is a slighty newer one here
https://downloadcenter.intel.com/download/19199/Audio-SoundMAX-Audio-Driver
however you would probably have to mod the driver to get it to work
https://linustechtips.com/topic/511679-win7-sound-issues/#findComment-6819346
This has solved the audio problem for now but there is now a slight bit of feed back in the back ground not sure what that is about i am checking my connections at the moment. It sounds like static
not surprising..that driver was made for win 7...could try the 6620 if you know how to mod a driver
your best option is to disable the onboard audio and just buy a cheap soundcard thats properly supported in win 10
https://linustechtips.com/topic/511679-win7-sound-issues/#findComment-6819415
