Is there made any better airflow case than my air 540 case? :-)
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/511286-best-airflow-case/
yeah its called a testbench
https://linustechtips.com/topic/511286-best-airflow-case/#findComment-6815123
Also btw is your system loud in there?
My 560ti is the loud thing. Sold my 7990 because i had a good price for it ;)
First gen asus dc2 coolers are shit :D
Built  Not Bought
https://linustechtips.com/topic/511286-best-airflow-case/#findComment-6815164
I don't think so apart from open air test benches
Aside from an open-air case, probably not.
Well, then I wont change my case :D
Built  Not Bought
https://linustechtips.com/topic/511286-best-airflow-case/#findComment-6815169
Gonna throw in the Silverstone FT02 into the ring with the 3x 180mm Air Penetrator fans blowing up the 90 degree-rotated mobo layout.  It's a pretty huge case but most still consider it the best for airflow.  Downside is that cable management isn't as easy as the 540 since it's not a dual-chamber design that keeps cable mess away from the main area with mobo and video card, but if you do it right then it's a serious contender if not better overall.
https://linustechtips.com/topic/511286-best-airflow-case/#findComment-6815201
