my friend is thinking of selling loop. I am interested in it but i know he has a amd 8350 i have a i5 so im trying to figure out what block this is to buy the mounts for my cpu. Could any of your fine ladies and gentlemen help me identify it. m5twt.jpgm5tJT.jpg
https://linustechtips.com/topic/510896-help-identify-this-block-please/
I dont recognise it, good chance its swiftech lol
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Somthing wrong with swiftech?
Not at all, just isn't a brand we don't come across in the UK
Ryzen Ram Guide
Oops, I meant Asetek.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
Well my friend is willing to sell me his whole loop the 290xs  16 gigs of ram and the psu for 550 but i dont know if i should
2x 290x is worth that alone! Waterloops add up fast, trust me I know lol I spent around $200 on fittings alone for mine. You should snap his hand off
Ryzen Ram Guide
Swiftech is great, the OEM so many closed loop coolers it's crazy. Corsair, Cooler Master, even NZXT all use Swiftech.
Wtf?
those are not made by swiftec...they are made by asetek and coolit, which are FAR better quality than the swiftech "expandable" AiOs
they use fairly low quality parts from china
their "expandable" AiOs have a high failure rate, and several leaks already
the problem is mostly the matterials they use to save on cost
that is how they can make a tiny custom loop for $150
the EK predator which uses proper quality parts costs $250+
and even then its not the best watercooling parts available...
Do you know what cooler that is
can't really see it clearly from the pic
it has a metal top though so slight chances are its from heatkiller
Wtf?
OOPS.
I don't keep up to date with water cooling, and the names sound so alike. Fixed.
The Laptop:
The  gpu block is but i think the cpu block says alpha cool
well then if it says alphacool then it must be an alphacool block :P
if its discontinued though they you will have a hard time finding the mounting hardware...
So pull the trigger
Yep, even if the block is turd, you can pick up and EK Supremecy and add it to that loop. Your friend is really giving you a bargain there for a full loop, 2x 290x and a PSU.
In perspective (ok mine is dual loop) I spent around £600 - £700 on watercooling components alone for my system and that's including the sponsorship I got. It would be £800 without that probably more. add to that 2x 970gtx at £500 and £100 for my PSU that's £1300 (around $2000).
Ryzen Ram Guide
I have  a h100i gtx right now
Custom loop will blow that out of the water by like -10C
Ryzen Ram Guide
well i mean if the current block doesnt work and i cant find mounts i figured id sub it in for the time being. So for 550 you think the case and all thats a good idea?
absolutely. You could sell you H100 and it would prob cover the cost of an EK Supremecy, theyre quite cheap
Ryzen Ram Guide
