Hi Computer builders
I'm planing on building my first gaming pc, I'm still saving some money to build it, I planned to build it in about 6 months.
My questions is, will it be good enough when I put it together or should i get some newer stuff that becomes cheaper when I build/buy it?
And does my rig work proper or do I get Bottlenecks, and any other advice what i should change to my rig (add/remove, replace) my budget is around 1000€ or 1095 $.
at this moment my chosen rig:
EDIT V2:
On pcpartpicker.com
Cpu:                Intel Core i5-4690K 3.5GHz Quad-Core Processor
Cpu cooler:       Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard:    MSI Z97-GAMING 5 ATX LGA1150 Motherboard
Ram:               Kingston HyperX Fury Black 8GB (1 x 8GB) DDR3-1866 Memory
SSD:                Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
HDD:               Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video card:       MSI Radeon R9 390 8GB Video Card
Case:               Phanteks Enthoo Pro ATX Full Tower Case
PSU:                Cooler Master VSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply
Thanks for the help of the first 4
I think this will be my build need any changes?
https://linustechtips.com/topic/510771-planning-on-building-first-computer/
Go with intel, unless intel is completely out of the budget. If you do go with the AMD Chip please get a 990FX board to put it on. The 970 chipset isn't really optimal for AMD FX 8 core chips.
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
Get a 390 instead of the 970.
An i5 would probably give better performance for a bit more but that is up to how much you want to spend, also you can save a bit on the RAM and go with 8GB if this is mainly for gaming.
P.S. Welcome to the forums :)
Go for a 390 in stead of the 970 because they both cost nearly the same but the 390 is faster than the 970.
The Asus UX305 has an Almighty Intel core M-5Y10 0.8GHZ, GPU Intel HD 5300 Windforce, SDD 120GB, Passively Cooled, 1920x1080 Matte Screen, An Fantastic ICEpower Audio Making my House Shake and Having more ports then a MacBook btw this not an advertisement.
From the german part picker
PCPartPicker part list: http://de.pcpartpicker.com/p/T7vHP6
Price breakdown by merchant: http://de.pcpartpicker.com/p/T7vHP6/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  (€275.29 @ Amazon Deutschland)
Motherboard: Asus H97M-E Micro ATX LGA1150 Motherboard  (€89.89 @ Amazon Deutschland)
Memory: Kingston HyperX Fury Blue 8GB (1 x 8GB) DDR3-1600 Memory  (€40.70 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€51.45 @ Amazon Deutschland)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card  (€352.08 @ Amazon Deutschland)
Case: Fractal Design Core 1000 MicroATX Mini Tower Case  (€40.26 @ Amazon Deutschland)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  (€77.89 @ Amazon Deutschland)
Total: €927.56
Generated by PCPartPicker 2015-12-23 00:12 CET+0100
