Tight budget for this, budget was honestly $500 but a little over is fine but how is this for just some basic overclocking and gaming? Yes I know theres is no GPU included or case but that's because we already have a case and graphics card. My biggest worry is the cooler, can I at least get a 4.0GHz OC with this cooler though and this board? Thank you for any help.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($223.99 @ SuperBiiz)
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler  ($23.25 @ Newegg)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($84.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($77.88 @ OutletPC)
Total: $536.99
Generated by PCPartPicker 2015-12-22 17:24 EST-0500
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
https://linustechtips.com/topic/510752-basic-overclocking-build/
The first question is what do you consider acceptable for temps? That cooler should allow you to get to that, assuming the chip is up to it, but I cant guarantee low temps.
CPU: Intel Xeon E3-1231v3 XX Motherboard: ASRock Fatal1ty H97 Killer XX RAM: G.Skill Ripjaws X Series 16GB (4 x 4GB) DDR3-1600 Memory XX GPU: Asus GeForce GTX 780 3GB DirectCU II XX Case: Phanteks Evolve ATX XX Storage: Kingston SSDNow V300 120GB SSD ; Western Digital Caviar Blue 1TB HDD; Western Digital Caviar Blue 3TB HDD XX PSU: Thermaltake SMART 550W 80+ Bronze
https://linustechtips.com/topic/510752-basic-overclocking-build/#findComment-6809400
Highest acceptable temp I would say would be maybe like 75C at full load.
https://linustechtips.com/topic/510752-basic-overclocking-build/#findComment-6809451
I've never used that cooler before, just been going off the specs listed for it, and thats going to be close.
https://linustechtips.com/topic/510752-basic-overclocking-build/#findComment-6809487
not happening with that piece of shit cooler. spend more and get a dark rock pro 3 or nh d15
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/510752-basic-overclocking-build/#findComment-6809498
Any particular air cooler around the same price maybe $10 more that would allow that possibly?
https://linustechtips.com/topic/510752-basic-overclocking-build/#findComment-6809499
Well, can only budget like $10 more at most.
https://linustechtips.com/topic/510752-basic-overclocking-build/#findComment-6809501
well then this isnt a very good overclocking build LOL
https://linustechtips.com/topic/510752-basic-overclocking-build/#findComment-6809506
4.0GHz is easy with that setup.
Cooler will be okay with it.
https://linustechtips.com/topic/510752-basic-overclocking-build/#findComment-6809511
