single GPU
https://linustechtips.com/topic/510220-help/#findComment-6803376
This Christmas I'm going to be upgrading my GPU horsepower in my PC and I'm wondering if i should get dual r7 370 in crossfire on my MSI gaming 3 MOBO
or should I just get a single r9 390?
A single card is usually better than 2 (If both configurations have the same effective performance)
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/510220-help/#findComment-6803379
Go for the 390. So few games will actually properly benefit from the Xfire setup, not to mention that there are so many more problems with settings, micro stuttering, and other graphical glitches.
https://linustechtips.com/topic/510220-help/#findComment-6803391
