First Ever Water Cooling Setup help !
Solved by Enderman,
sounds like you need to do a bit more research and learning before you try to build a custom loop
unless you have the $400+ for the parts and experience to build it, you should probably just buy an AIO
if you really do have all that money to spend on aesthetics, then start learning here:
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8
play_circle_filled
Latest From ShortCircuit:
