http://pcpartpicker.com/p/HgzqCJ
Budget- trying to keep it under 1500$ usd (this is without os and peripherals)
im saving for a computer and this is what i put together in pcpartpicker. going for a black/white build because i fell in love with the msi krait boards when i found them on newegg. as for overclocking i don't know how to do it, so there is a good chance it wont happen, atleast not right away.. so what are your thoughts?the psu comes with black cabling, so if i want white, do i buy sleeving and just slide it on or do i get pre sleeved stuff like this?  https://www.pccasegear.com/products/29075
this is going to be my personal pc, and ill be playing games,watching videos and surfing the web. and the occasional use of SAI and photoshop.
for ram im thinking of either the 2x8gb hyperX fury white kit or a 2x4gb of hyperX black kit and a 2x4gb hyperX white kit (would the black and white set work? using 1600 ddr3 kits same timings)
also if you can think of any easy case mods i would love to hear them. i plan on getting a msi krait vinyl decal for either the back side or front panel. and little ones for the center of the fans. i want to do something simple with white led lights and a msi krait snake logo, but cant think of anything.
so......thoughts?
wont be built till late 2016 so i have time to tinker with it.
https://linustechtips.com/topic/510065-build-planning-thoughts/
Maybe a cheaper GPU (R9 380) and an i7
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/510065-build-planning-thoughts/#findComment-6801359
Not much point in putting a PC together now, what's your current PC?
https://linustechtips.com/topic/510065-build-planning-thoughts/#findComment-6801414
my current pc is
cpu- g2030
gpu- 7770
motherboard- gigabyte ultra durable 4 classic
ram- 8gm g.skill ripjaws
psu-corsair cx500
hdd-seagate barracuda 500gb
the reason for the xfx 290 is mainly because i like how it looks. the light up xfx and and black with chrome trim is just awesome.
and when i say late 2016 it all depends on how many hours i get at work and how i save my money. i don't have bills, so i could take 3-4 months to save enough or like i said late 2016.
https://linustechtips.com/topic/510065-build-planning-thoughts/#findComment-6801777
my current pc is
Well my suggestion is to reject aesthetics until your budget is unlimited
Otherwise you should really just maybe upgrade your CPU, maybe throw in an SSD 480gb is like $130 right now, and then you're good to go on that front,
After that I'd suggest you get a new PSU/GPU and Add in a free-sync display of some kind, either 144hz 1440p or the 4k IPS displays that are around 500, that upgrade would probably run about $1000 and you'd be set as far as gaming goes for a long while, your CPU isn't going to hold back games if you upgrade to an i5
i5s are apparently about $150 used on amazon
http://www.amazon.com/Intel-Core-i5-3570K-Quad-Core-Processor/dp/B007SZ0E1K
Of course by next year kaby lake and zen might be out, as well as HBM2 GPUs, and probably new cheaper free-sync displays, so again, not too much point in planning now, save up like a couple grand for next year's black friday and by all your stuff then
https://linustechtips.com/topic/510065-build-planning-thoughts/#findComment-6801833
get a 390 by powercolor/xfx to match the build.
also take a look at Asus Z97 Sabertooth Mark S, it will fit the build even better.
i looked at the sabertooth when i was first considering building a new pc, i just did not like it for some reason. but im thinking i might go with the xfx390. thanks.
i might wait till then. i just felt, if i dont start this now, it may never get done xD grabbing that i5 for my current pc does sound like a good idea. and i do plan on giving this pc to my brother once i upgrade. so thats nice, what gpu(amd if possible) and psu would you recommend for my current pc?
and if the new stuff is out by then, i can either plan to build with that or maybe the price will go down for the stuff im thinking of using.
https://linustechtips.com/topic/510065-build-planning-thoughts/#findComment-6802043
there's the starter upgrade pack anyways, I think you can find the display for less with a google search, and maybe someone will release a 1440p IPS 60hz Free-sync display sometime next year, that'd be about the perfect display to get
this one's 1080p 21:9 IPS, the other option at around the same price is 1080p 144hz TN
PCPartPicker part list: http://pcpartpicker.com/p/DWvp7P
Price breakdown by merchant: http://pcpartpicker.com/p/DWvp7P/by_merchant/
Video Card: Gigabyte Radeon R9 390 8GB Video Card  ($295.99 @ NCIX US)
Power Supply: Rosewill Hive 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.89 @ OutletPC)
Monitor: LG 29UM67 60Hz 29.0" Monitor  ($309.99 @ Amazon)
Total: $675.87
Generated by PCPartPicker 2015-12-21 18:29 EST-0500
https://linustechtips.com/topic/510065-build-planning-thoughts/#findComment-6802143
I would recommend going skylake if you have this big of a budget. However, the Z170 krait motherboards from MSI are not on pcpartpicker. So I requested they put them on and they should be there in one or two days. Then I can recommend some parts for a skylake build.
https://linustechtips.com/topic/510065-build-planning-thoughts/#findComment-6802181
there's the starter upgrade back anyways, I think you can find the display for less with a google search, and maybe someone will release a 1440p IPS 60hz Free-sync display sometime next year, that'd be about the perfect display to get
Total: $675.87
ok thanks.
this is very helpful, i just love the msi krait board/theme. which is what i want to build my system around. and having both a 1150 and 1151 option for when i do upgrade will be nice.
https://linustechtips.com/topic/510065-build-planning-thoughts/#findComment-6802343
ok thanks.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($279.99 @ B&H)
CPU Cooler: Corsair H110 94.0 CFM Liquid CPU Cooler ($104.99 @ Newegg)
Motherboard: MSI Z170A KRAIT GAMING ATX LGA1151 Motherboard ($134.99 @ Amazon)
Memory: Kingston FURY 16GB (2 x 8GB) DDR4-2666 Memory ($109.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive ($89.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.98 @ OutletPC)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card (2-Way CrossFire) ($184.99 @ Newegg)
Case: NZXT Phantom 630 Windowed Edition (White) ATX Full Tower Case ($145.99 @ SuperBiiz)
Power Supply: Corsair 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($152.95 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($17.88 @ OutletPC)
Case Fan: Aerocool DS 120mm White 81.5 CFM 120mm Fan ($16.99 @ SuperBiiz)
Case Fan: Aerocool DS 140mm White 93.4 CFM 140mm Fan ($15.99 @ SuperBiiz)
Total: $1489.71
Generated by PCPartPicker 2015-12-22 14:32 EST-0500
https://linustechtips.com/topic/510065-build-planning-thoughts/#findComment-6808101
