I just bought a second display, plugged it in and it turned on just fine. I plugged the new one into hdmi and the old into the dvi on my gpu (stupid 750ti only has one hdmi) and the old one says no input. Do I need some sort of software? what should I do?
Make sure in display settings it's detected and enable it so that you can extend onto that monitor.
https://linustechtips.com/topic/509629-dual-display-help/#findComment-6796256
does it show up in your GPU control panel or windows display settings?
is the display set to the correct input?
https://linustechtips.com/topic/509629-dual-display-help/#findComment-6796257
ok got it thanks
How do I have my tray/ programs bar only show up on one display?
https://linustechtips.com/topic/509629-dual-display-help/#findComment-6796270
ok got it thanks
If your running Windows 10 they set it up as both I don't believe there is a way to only have one, Windows 7 previously only gave one and no option to add more.
https://linustechtips.com/topic/509629-dual-display-help/#findComment-6796341
