Hi Guys. I've just realized that i haven't got bluetooth on my new build. I need it for connecting my Dualshock 4 to play some rocket league. How can i get bluetooth.
OS: Windows 10 OEM
Motherboard: Gigabyte GA-Z170X-Gaming 3-EU
Thanks in advance
/Crushader
https://linustechtips.com/topic/509232-first-build-no-bluetooth/
OS: Windows 10 OEM
Thanks in advance
/Crushader
Order a cheap bluetooth adapter online or get a cheap one at a store.
Someone once said: "Having a rollercoaster on a PC would be epic"
So threw a rollercoaster on my K'nex PC: Project Dragon Khan- K'nex rollercoaster PC build
https://linustechtips.com/topic/509232-first-build-no-bluetooth/#findComment-6791500
I was :P
With desktops BT would be done with mobo, not by default as its with laptops. Most consumer grade mobos don't have BT or wireless. Your's doesn't either. You will need to get cheap USB adapter. Those are plug-n-play devices and will work with you just plugging one in.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/509232-first-build-no-bluetooth/#findComment-6797338
