Hello, so I was building my rig and had no problems until I tried to install my GPU.
Apparently my GPU (an MSI R9 380 4G) won't fit in the PCIe 3.0 x16 slots on my motherboard (an MSI H97M-G43) due to the fact that the notches on the ram slots block the graphics card from being inserted into the PCIe slot. So I had to install it into the PCIe 2.0 x4 slot, which to me sounds extremely unoptimal? Will there be any dire side effects or bottlenecking caused by that?
I really don't know what to do, judging by what I had to do it seems as though I might have thrown out a lot of performance out the window due to a shoddy mobo design :/
https://linustechtips.com/topic/509024-massive-issues-with-installing-gpu/
The bottom slot is also X16.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
did you push the ram in all the way, so the clips click back in? If so, maybe try it again.
it actually isn't (and you can see it in the picture, look closely at the slots. The gold contacts don't run the full length of the second slot.)
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
well its atleast x8, because they have a picture with them running 2 gpus, and anyhow, there is NO reason for your GPU not to fit, unless you have a very thick heatspread on the PCB or your rams headsinks really flare out
Proud Member of the Glorious PC Master Race
its a problem on some MSI motherboards, as the little ram button blocks the first card sometimes and sucks attempting to put bulky cards in
Then what's this?
post-233981-0-69110300-1450600919_thumb.
