So this is what i was thinking of, I will give some information as to why i chose everything but there are a few where i'm not so sure about. firstly My budget is $1400 USD maximum, this includes everything ranging from mouse/keyboard to OS and monitor, but it does exclude things like thermal compound or things needed to build the pc. I would prefer if possible i could go under $1300 but $1400 is still OK. my main reason for the build is definitely gaming, i play lots of different games(including the new ones too come) so i would prefer it to be future proof for at least the next 2-3 years. I will not be buying this in the US but most of the prices for these parts are the same from where i am from unless stated below.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($79.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($77.88 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($328.99 @ SuperBiiz)
Case: Corsair 200R ATX Mid Tower Case  ($47.99 @ Micro Center)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($17.99 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($89.89 @ OutletPC)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($39.75 @ OutletPC)
Monitor: Asus VG248QE 144Hz 24.0" Monitor  ($239.99 @ Micro Center)
Headphones: Logitech G930 7.1 Channel Headset  ($69.99 @ Amazon)
Total: $1382.16
Generated by PCPartPicker 2015-12-18 11:45 EST-0500
So my main problems is the CPU and motherboard, for now, i stuck to a i5 4460 even though i was thinking of the 4690k as i may do some overclocking and it looks a lot better for the future, as for the motherboard i really am clueless about this part, i dont need a great looking one, just one that has its utilities and wont be totally useless in the future.
CM hyper 212 evo just for cooling, heard its best bang for buck so why not? any other better/cheaper options?
the gtx 970 is what i really wanted the most, i did think about the r9 390 but in my country it was a lot more expensive than the gtx 970, don't worry as most of the other parts are around the same price, only the r9 390, no clue why
16gb ram so i wont need to worry about getting more in the future, i chose this brand as it was the cheapest i could see :P ram is ram haha
corsair 200R as i went for a cheaper case, dont mind the looks, would like recommendations on this aswell
1TB HDD nothing to say, 250GB SSD instead of 128GB as i may need the extra bit in the future
corsair CX 600W i chose and can change if this pc needs more or has too much, i chose this just as an average good power supply
Asus VG248QE is extremely necessary for gaming or so i was told, probably wont change this, and no i dont have any other monitors
everything else i just picked because its necessary and went with the higher/cheaper good review products, windows 8.1/10 i dont mind any, im not sure about the headset and mouse/keyboard yet, for headset i prefer a higher quality microphone over the sound and for mouse/keyboard i just need something that works (dont mind it being wired) lol
any help/recommendations on anything would be helpful, any questions just ask away!, thanks
https://linustechtips.com/topic/507953-first-gaming-pc-help-appreciated/
Do Not go with a CX PSU, something from EVGA, or Seasonic please. That's all you really need to change.
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
get a better Power Supply the cx is not very good for high power gaming rigs.
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
Change the psu
-snip-
here is a more balanced build with some better quality parts also your headphones are ok but these are better:
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  ($28.99 @ NCIX US)
Motherboard: Gigabyte GA-H97-HD3 ATX LGA1150 Motherboard  ($89.75 @ OutletPC)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($41.99 @ Amazon)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive  ($54.99 @ Adorama)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.88 @ OutletPC)
Case: NZXT Source 220 ATX Mid Tower Case  ($84.98 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($64.99 @ SuperBiiz)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($19.99 @ Newegg)
Headphones: Kingston HyperX Cloud Core Headphones  ($69.99 @ NCIX US)
Total: $1393.15
Generated by PCPartPicker 2015-12-18 12:23 EST-0500
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
Great input guys! i'll definitely change the psu, do i just need a different brand or get a higher wattage psu too?
I may do video editing/rendering which is why i kept the ram, and the ram is the cheaper parts in the build which is why i dont worry too much about it, will swap it for 8gb if needed!
i heard a lot better reviews on the G930 compared to the cloud, although i'll do more research before buying it, thanks for the tip
