Optical drive?
Go to solution Solved by MegaDave91,
Always download the latest from the manufacturers' websites. If you have no means of doing so, then yes, you need an optical drive to install the drivers for the wireless network card.  Once you have internet connectivity you can download the rest.
https://linustechtips.com/topic/507771-optical-drive/#findComment-6775621
