Anyone know how to spin a blade fast enough using hand power?
SeanAngelo
Not nearly enough. I would say at least 4000RPM.
Just to tell you, we won't actually be putting fruits in and see if it works in order to pass the project. We just need to set a suitable RPM for it work, not too low of an RPM but not too high where you are not able to achieve it using gears.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Oh then yeah 720 is fine.
(Feel free to correct my maths, never was my strong point, but the theory should be sound)
If you could use the 120 tooth and 30 tooth gears you mentioned earlier then you should be able to get 960rpm out of a compound gear train. If the 120 tooth turns at 1rps then the 30 turns at 4. This gear is on the shaft as a 120, so this new 120 also turns at 4 RPS. We then take another 30 tooth gear and if driven of the 4 RPS 120 tooth, it will turn at 16 RPS.
16*60=960
This all assumes you could only turn the first wheel 1 time every second, but realistically you should be able to turn it 2-3 times a second, so that means 1920-2880rpm
RIG:FX-6300@4.5GHz 1.4V with Hyper 212 evo with LTT NF-F12:MSI Overclockers R7 260X:4x4B Crucial Ballistix Sport:GA-970A-UD3P:1TB Seagate Brracuda & 120GB Crucial M500(OS and Programs)&Sandisk SSD PLUS(Games) In a Bitfenix Comrade with an NF-F12 as exhaust and OEM case fan as front intake
''time you enjoy wasting is not wasted time''
