System clock running too fast
OVerclocked a...clock? What? Restart your PC.
After overclocking my i7 920 from 2.66 to 3 I have noticed that my system clock has started running slightly faster that it should.
Over time it gradually gets ahead of what time it should be at but it can be manually fixed by syncing with time.windows.com
A "minute" for my system clock lasts for ~53s on my phone. (which works perfectly into the ratio of 2.66 to 3)
I am not sure if I have done anything wrong on my overclock or it is something else causing the issue.
OS: Windows 8 pro
CPU: i7 920
MoBo: P6T Deluxe V2
RAM: 12GB DDR3 1600MHz
I have also noticed that task manager thinks I still have old clock speed, while CPUZ reads it as 3GHz which I expect it to be.
http://i.imgur.com/wXqSc8e.png
(task manager on the left, cpuz on the right)
