If I put the radiator on the front of the case, would it matter if I use SP fans on the front? I've read you should use SP fans on radiator, but you shouldn't use SP fans for general intake. It seems like it would be fine, since it technically isn't general intake, but I want to be sure before I order parts and everybody has pretty helpful with my questions. This would leave me with 1 airflow fan as an exhaust, with 3 SP fans (top and x2 radiator front).
https://linustechtips.com/topic/505868-fans-questions/
You want SP for radiators, so yes, put them on the radiators.
Also, for me at least, I like using static pressure fans for my intakes anyways.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/505868-fans-questions/#findComment-6751934
Static pressure fans can be an intake just fine, the direction of air moving in or out of the case doesn't matter in the slightest.
What you don't want to do is have static pressure fans just as general case fans, there are quieter and more efficient fans for that. (Airflow oriented fans)
But since it's on a rad, then its totally fine to use static pressure fans as an intake.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/505868-fans-questions/#findComment-6751937
Alright, awesome. Thanks for the reply. This is my first build and I wanna get it right the first time.
Thanks for the reply, I appreciate it.
https://linustechtips.com/topic/505868-fans-questions/#findComment-6751951
