Tbh, Im going to keep posting this until someone helps.
My specs:
CPU : AMD FX™-8350 Eight-Core Processor
GPU : MSI R7770 Power Edition
6 gigs of DDR3 Hyperx
MOBO : GIGABYTE GA-970A-D3P AM3+/AM3  AMD 970 6 x SATA  6Gb/s USB 3.0 ATX  AMD Motherboard
Temps are constant 40C-45C at 30 fan speed
I cleaned the dust out with an air can and flipped my PSU around so the fan was upward to prevent more dust buildup.
I also cable managed a bit.
I cleaned out some dust yesterday and all of a sudden in csgo my frames go from 300 (which is what i usually get to around 60 almost 2 times per sec and and the max fps i get now is around 100. I dont know if something broke.
https://linustechtips.com/topic/505520-gpu-problems/
Well can link me because this forum doesnt provide that much help
Google "AMD 7770 Drivers" and download them from AMDs website.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/505520-gpu-problems/#findComment-6747333
Also, quote people or use @*insert username* to get their attention and follow your posts so you get a notification when someone replies to your topic.
https://linustechtips.com/topic/505520-gpu-problems/#findComment-6747351
Guest
