filter OK for nf-f12?
Solved by KamiKatze,
As the description says, its a very dense foam, compared to low restriction mesh-filters. so you'll get great filtering, but maybe reduced airflow. make sure that the nff12 is well sealed against the intake. Will be no problem though since the nff12 has a relativeley high static pressure.
Will be somewhat sound dampening aswell.
Real_Smoky ·
Posted in Graphics Cards1 -
ArushM ·
Posted in Troubleshooting1 -
2
2
jobba57 ·
Posted in New Builds and Planning3 -
18
15
