Guys, Which air cooler can keep my 5960X stable with 4ghz OC? I'm going full custom loop soon but I need an air cooler for temporary use for the following two months before I can complete my build. I'm interested in Noctua NH-U12S. I'm running push pull with dual 120mm Fractal Design Venturi HP fans. My case is Fractal Design Define S with three 140mm Fractal Venturi HP fans as intake and 1 140mm Fractal Venturi HF fan as exhaust. I really need an air cooler that wont block my 128gb ram and the first PCI slot for my 980ti lightning. Please help.post-218976-0-48179600-1450049486_thumb.
https://linustechtips.com/topic/504899-5960x-cooler-help/
TC14PE (phanteks) or NH-D14 (if You can find one for sale)? :D
Hey bro i like yo *vomits on you*
SpOOkY  - Intel Core i7 4820K - Sapphire Radeon HD 7970GHZ Toxic Edition 6GB - 16GB Corsair Vengeance 1600Mhz - Gigabyte X79-UD3 - EVGA Supernova G2 850W
My GrApHiCs DeSiGn TeAcHeR Is GoInG To bE sO MaD
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6739198
probably most (if not all) 140mm, and some of the larger 120mm ones.
if you're doing a custom loop soon, just get something cheap that handles it at (near) stock speeds. No point spending more than you really need (that said this is a 5960X we're talking about).
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6739211
Guys, Which air cooler can keep my 5960X stable with 4ghz OC? I'm going full custom loop soon but I need an air cooler for temporary use for the following two months before I can complete my build. I'm interested in Noctua NH-U12S. I'm running push pull with dual 120mm Fractal Design Venturi HP fans. My case is Fractal Design Define S with three 140mm Fractal Venturi HP fans as intake and 1 140mm Fractal Venturi HF fan as exhaust. I really need an air cooler that wont block my 128gb ram and the first PCI slot for my 980ti lightning. Please help.attachicon.gifIMG_20151213_1.png
nh-d14
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6739236
A bit off topic, but how do you have 128 gb of ram if only two slots are filled?
2 on the other side are filled. x99 has 4 slots on each side of the motherboard
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6739265
Thats only 96GB though (6 banks)
But this build doesn't look complete in the picture, no expansion cards and no CPU
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6739316
Yeah... there must only be 64 in there right now because G.Skill doesn't sell 32GB sticks
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6739330
I don't know why people use 128gb ram, its a little extreme considering 16gb - 32gb is the norm/pushing ott
Ryzen Ram Guide
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6739352
That's fucking sexy.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6739604
Guys this is more of a showcase build for my youtube channel and there is currently 4x16gb ram on this board. Like I said this build is not completed. Im looking for a temporary air cooler. I prefer something that i can use my spare Venturi HP 120 fans. The Nhu12s got single tower and im throwing that nff12 away and use the two venturis. Its for temporary. Will it handle 4.0 or 3.8 fine? I cant find any solution online. Also any other cooler with 120mm fans support that wont block the ram and first pci slot? I kinda want smaller cooler for showing the ram too. But still just for temporary and component testing. Ill reuse the cooler for other projects when my paycheck come for the custom loop.post-218976-0-35404600-1450053700_thumb.
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6739633
Guys this is more of a showcase build for my youtube channel and there is currently 4x16gb ram on this board. Like I said this build is not completed. Im looking for a temporary air cooler. I prefer something that i can use my spare Venturi HP 120 fans. The Nhu12s got single tower and im throwing that nff12 away and use the two venturis. Its for temporary. Will it handle 4.0 or 3.8 fine? I cant find any solution online. Also any other cooler with 120mm fans support that wont block the ram and first pci slot? I kinda want smaller cooler for showing the ram too. But still just for temporary and component testing. Ill reuse the cooler for other projects when my paycheck come for the custom loop.attachicon.gifIMG_20151213_2.png
I´m running X99 in all three CPU variations.
To OC an i7 5960X to 4.0GHz I´d go with an AIO for the time being. This CPU produces some heat when all 8 cores are running. An air cooler is not the best option.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6742676
No one can know what cooler you will need (not even you) until you figure out what voltage the 5960X needs to run at to be stable at 4.0.
There is no "temporary" cooler on the market. If you only need the cooler temporarily, why do you need it to run at a 4.0GHz OC? Just run the thing at stock with a $28 cooler like the 212 EVO and call it a day. The 212 can probably keep it under 85C at 1.3v, but not much higher than that.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6743797
I'm saying that 128 just to let people know ill use all 8 ram slots. Currently there are two ram sticks on each side. So just 64 for now. but ill add 64 more GB next month. And the cpu and GPU are not put in yet cuz there is no point since i dont have the cpu cooler and will have to remove the GPU anyway when i need to install the cooler. Thats why i need some ideas from people here in this forum.
I'll probably need 4.0 ghz for my usage. I said temporary cuz ill remove it soon when i need to OC and when it will be put underwater. I'll probably run it at 1.25v max for that 4.0 which is not an impossible thing to do for a 5960x. Is it possible for a NH-U12S to do 1.25v and keep it under 80°C? I'll use my spare two Venturi 120 HP fans on that NH-U12S if i need to buy one.
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6745075
Id pick up a used h80i or something if you can find one cheap used if its only temporary, should keep it under control even if you overclock it a bit. Also will hold its value and you can resell if your concerned about money (which looking at your rig you are not :) )
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6745283
Haha, i was giving reasons for you not having the 128gb fitted in response to a previous comment, not doubting your build (jealous lol )
Ryzen Ram Guide
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6747581
Again, if you're just going to ditch the cooler why are you paying $120 for an air tower when that could buy 1) an AIO or 2) a 212EVO for 1/4 the price? A single fan tower cooler is going to perform roughly within margin of error of any other
New-Microsoft-Office-PowerPoint-Presenta
Full review: http://www.dvtests.com/noctua-nh-u12s-test-and-review/
If you already have the NH-U12S then by all means, use it and see what it can push. If you're buying it, even at a huge discount, it simply isn't worth it over nearly any other option that is much cheaper.
There's no way to know if your 5960X will be able to hit 1.25v 4.0GHz, every chip is different. Same will go for the temps, although there will be a much lower margin of error given all the Haswell-E's are soldered (~Δ5C). 80C at load should not be a hard target for that voltage, on nearly any cooler.
https://linustechtips.com/topic/504899-5960x-cooler-help/#findComment-6748420
