Hello,
Need to get my dad  new USB as part of Christmas. looking for something that flashes as he leaves it in his computer sometimes which is annoying.
So I'm looking for flashing as a priority.
USB 3.0 preferred but not required.
Size really anything other 4GB i dont mind, his current is 256MB aha.
Any suggestions id like to see what you guys have got and used.
thanks
build it beaurtiful
https://linustechtips.com/topic/504657-usb-advice-christmas/
Sandisk and Kingston make some good USB sticks.
Just to let you know, it's not called a USB, rather a Memory stick or a USB stick.
USB is just referring to the type of connection.
I don't like 2D games...I just couldn't get into them.. ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/504657-usb-advice-christmas/#findComment-6736336
https://linustechtips.com/topic/504657-usb-advice-christmas/#findComment-6736341
wow.
I think you missed the entire point of this post...
build it beaurtiful
https://linustechtips.com/topic/504657-usb-advice-christmas/#findComment-6736386
None of them are incorrect, just some are more accurate than others.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
https://linustechtips.com/topic/504657-usb-advice-christmas/#findComment-6736389
