cheap and quiet 120 mm case fan
manofsteel
Hi,
I want to change my top fan (zalman default fan from the case) to some 3rd party fans that are quit cheap and good ofc . It must be fan that pushes air from the case. thx for any advice.
Cheers
CPU i5 6600k 4,4Ghz , COOLER Dark Rock 3 from BQ, RAM 16 GB of ddr 4 2800MHz from corsair,
 PSU EVGA 750 W GOLD G2, MOBO Msi z170A Gaming M3, CASE NZXT H440 Black/Blue,
GPU Geforce GTX 980 Gigabyte G1 Gaming,
STORAGE 1 SSD Samsung 850 Evo 250 GB and 1 HDD 500GB WD, Windows 8.1.
Noctua LinusTechTips Edition
Not cheap
I recommend noiseblocker.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
BeQuiet! Shadow Wings.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
lol
At least cheaper than Noctua or BeQuiet! Shadow Wings.
3.Use
dunno about this company any more information?
hmm i though about be quit to be specific a silent wings . Is there a diffrence between those 2 ?
I believe one is static pressure and one is air flow.
now i am even more confused O.o?
Where are you shopping/located? Budget?
Poland and bugdet hmm its hard because here in Poland euro is like 3,5 of my currency and US are more expensive :S.
There's no point converting to USD if that's not what you're using. Just state the budget in whatever currency you're using.
Please link us to where you're shopping.
http://www.morele.net/komputery/podzespoly-komputerowe/wentylatory-radiatory-chlodzenie-60/
thats where i shop and in my currency bugdet is somewhat near 60 or a little bit higher
bump because dunno if quote worked
Noiseblockers are good: http://www.morele.net/noiseblocker-l-xl2r-505773/
Please don't bump threads and be more patient. This is a forum and not a live messenger.
hmm what about http://www.morele.net/be-quiet-shadow-wings-sw1-120mm-pwm-bqt-t12025-mr-pwm-bl026-424187/?
and about bump well sometimes my threads are abandomed after couple of post (and yes i were quoting with another question) thats why i did sorry :C
Shadow Wings are better if you don't mind spending more but would really only be worth getting if you're replacing all of the existing stock fans you're using.
well that would be hard because i got nzxt 440 h case with only one extra fan from previous case which was zalman z3 plus (but damaged so..) and the zalman fan is quite noisy .
http://www.morele.net/noiseblocker-blacksilent-fan-xl1-120mm-itr-xl-1-552939/
what about this fan its stays in bugdet still and from what i see its quiet but is it good for pushin air from the case?
Sure, it's good but why spend more?
becasue dunno if 21 DBz will be considered as quiet xD
Fan specs are measured in varying environments and are generally unreliable. 21dBA is very quiet but I wouldn't count on it being that quiet in the average room.
That being said, the fan is definitely very quiet and you should be running it at lower speeds--in which case, the noise rating for the max rpm isn't that relevant.
Well i dont know if lower speed is good when counting fact that i got 3 front fans nzxt and only 1 back fan 140 mm and one on top and dunno if that 140mm fan will handle such burden of pushin out the hot air mainly alone. Oh and i got be quiet dark rock 3 with its massive fan too so i want to make as good air flow as possible and get a little bit quieter fan ;p
