if you record it with extreme overall bit rate(%90 is like 450mbps) you wont able to play it easy as you recorded it you have to downgrade the quality to (something like 16k kbps bitrate is fairly good for me) you will able to play it no problem
https://linustechtips.com/topic/50447-help-with-msi-afterburner/#findComment-672792
blinking? flickering? stuttering? got camera phone to shoot video of it?
https://linustechtips.com/topic/50447-help-with-msi-afterburner/#findComment-672845
