Is an M.2 drive worth it for O.S
Solved by vanished,
Compared to what? A SATA SSD? A HDD? If you can find an M.2 SSD for the same price/size as a normal SSD, I'd say yeah go for it, why not. If you can't though, I suppose like anything you have to decide if it's worth it. Personally, I think SSDs are a necessity, but going beyond that to M.2 or PCIe, etc. is probably overkill for the vast majority of people.
Edit: Nvm, please get a 1.2 TB Intel PCIe SSD. That mobo is almost $750 CAD, so clearly you've got the cash
