JSRS mod is an incredible sound addon
www.youtube.com/watch?v=_4-i_-Ar8rQ
www.youtube.com/watch?v=sZmZzZxEG4E
www.youtube.com/watch?v=L6mPCH1H_7c
The mod can be downloaded on this site. JSRS 1.x is for Arma 2, while Arma 3 uses JSRS 2.x. All you have to do is combine all of the updates (if applicable by starting with the oldest version first, then adding/overwriting the older files with the newer ones) in to your Program Files>Steam>SteamApps>common>Arma 3>"@[insert folder name]" to look something like this:
Then simply right click Arma 3 in your Steam library>properties>Set Launch Options>enter "-mod=@[insert folder name]" (and add a ";" immediately after that folder name and type "@[insert folder name 2/3/etc.]" to enable other mods upon launch). You're done, enjoy a much more immersive experience and let me know if you have any questions
https://linustechtips.com/topic/50420-sound-mod/
Thanks for this. Will download when I get home. :D I wonder if Day Z is compatible with it. That would be legit.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/50420-sound-mod/#findComment-672500
  • 1 month later...
None of these vids work on mobile devices, when one did play chrome crashed. Wtf is going on with my ipad.
umm.. it´s from apple? (yeah i dont like them) maybe its just old and slowly singing its last song, time for a new device mate! try Factory reseting it, or take it to a ...person that might be able to fix, or buy a new :)
https://linustechtips.com/topic/50420-sound-mod/#findComment-951716
https://drive.google.com/?usp=chrome_app#folders/0BzJ0L2P0kpprSFZiTGZ6U28zT1k
Enjoy. They're almost all at 4K resolutions, so it may take a while to download.
W.E, is that to donwload all your drive???
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/50420-sound-mod/#findComment-952660
