Hey folks.
The H440 case has a fan hub thingy at the back. Are you able to buy those?
If so any links?
Much appreciated.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/502104-fan-controller/
https://linustechtips.com/topic/502104-fan-controller/#findComment-6703625
Awesome. Exactly what I am looking for.
I guess that would cause the fans to run a full speed all the time right?
https://linustechtips.com/topic/502104-fan-controller/#findComment-6703645
no
you can control the fan speed with one cable that plugs into a regular fan controller or your motherboard
but they will all run at the same speed
https://linustechtips.com/topic/502104-fan-controller/#findComment-6703664
