What is the absolute best cooling solution for a CPU for noise and performance? I was looking at bequit stuff are these good?
I currently have a 212 and its just so noisy. Case fans are silent wings 2. Case is tx10. Cooling a non overclocked 5820k
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
https://linustechtips.com/topic/501490-best-cooling-solution/
Absolute best? Custom liquid.
Absolute best air? Noctua.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695722
on air bequiet for looks and performance, noctua only for performance
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695729
You could take a Noctua or a Be Quiet! air cooler or go for an AIO watercooling like the Corsair H100i, but it has 2 fans so if you don't overclock, you should go for an air cooler.
|| CPU - i7 4790K @4.6GHz || GPU - MSI GTX 980 Gaming 4G || Motherboard - Asus Z97-A || RAM - 16GB Kingston HyperX Fury @1866MHz |Case Be quiet! Silent Base 800 ||
|| CPU Cooler - Cooler Master Hyper 212 EVO || Storage - Samsung 850 Pro 256GB & Seagate Barracuda 2TB (+ WD Caviar Green 2TB) ||
|| Mouse - Logitech G502 Proteus Core || Keyboard - Corsair K70 (MX Red) ||
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695731
noctua?
Arent those very noisy?
Actually I thought about that. But isnt liquid cooling much noisier then air?
ok
I have an h100i in my other computer and its wayyyy to noisy. Hate that thing.
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695748
As you didn't put any budget on it I'll just suggest LN2 because you can keep it pretty much passively cooled and have incredible cooling at the same time.
Someone once said: "Having a rollercoaster on a PC would be epic"
So threw a rollercoaster on my K'nex PC: Project Dragon Khan- K'nex rollercoaster PC build
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695761
Isn't that liquid nitrogen cooling? kinda wanted to stay on air or a custom soft tubing loop. Dont want anything complicated :P
But thank you for the suggestion :)
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695776
LN2 is indeed liquid nitrogen but I already guessed you wanted to stay away from anything complicated, however, if you wanna go full BS you can do something like this and couple it to the CPU in some way:
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695801
Keep ur cooler and just replace the fan with a Noctua NFF12.
or go ham and get a Noctua NH-D15.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695899
If you plan to go as silent as possible and you have some coin in your pocket, then you can go custom water passive. The fact that you speak about a 5820K without OCing makes passive an option here. Your TX10 gives you a huger number of possibilities for radiators.
No fans and with a D5 PWM pump very low pump noise (almost not auditable).
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695902
How would I go about doing this?
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695937
It isn´t really hard to go passive as long as you use the right components and don´t plan to put too much in that loop especially GPUs. They just generate too much heat and therefore the radiator surface would get ridiculous.
But dfor a CPU you´d make sure to use a very good CPU cooler with a very tight FPI rate and enough radiator surface to keep the machine going without running into critical temps. Pump is also a very important factor. Tubing not so much because you´d abyway be limited by the smallest ID for your flow rate. Speaking of which you want a variable pump for the right flow rate.
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695979
How much rad space do you think I'd need for achieving this? What do you think idle/high temps would be?
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6695991
I need to do some maths here first. Usually I build high performance custom watercooling for OCing hehe. I can PM you and give you a list of all parts you´d need if you want.
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6696011
Dark Rock Pro 3 from BeQuiet is pretty cool...yes cool in temps as well.
You can bark like a dog, but that won't make you a dog.
You can act like someone you're not, but that won't change who you are.
Finished Crysis without a discrete GPU,15 FPS average, and a lot of heart
How I plan my builds -
For me I start with the "There's no way I'm not gonna spend $1,000 on a system."
Followed by the "Wow I need to buy the OS for a $100!?"
Then "Let's start with the 'best budget GPU' and 'best budget CPU' that actually fits what I think is my budget."
Realizing my budget is a lot less, I work my way to "I think these new games will run on a cheap ass CPU."
Then end with "The new parts launching next year is probably gonna be better and faster for the same price so I'll just buy next year."
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6696014
It doesn't have to be. It can be quieter than air, it just depends on what parts you buy.
The Laptop:
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6696032
Thatd be amazing!
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6696108
I guess thats true. My comparison is that I have a h100i which is mega noisy.. Then i bought be quit silent wings 2 fans.. Even with all 10 of them installed at max you can barely here them.
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6696114
Exactly.
Plus this is also cheaper than the Noctua NH-D15.
I myself am using a CM Hyper 212X :lol: no problems so far, I left it with the PWM header on the motherboard so I haven't heard much coming from it.
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6696150
Thatd be amazing!
Aight I´ll get to it now. PM you when I´m ready.
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6696152
Ok thank you very much!
https://linustechtips.com/topic/501490-best-cooling-solution/#findComment-6696169
