Radiator Questions
Go to solution Solved by Enderman,
They make white versions of all three types of rad. Just curious as to which thickness to get. The thinnest for less noise?
oh they released new ones
well just get the one that fits in your case
the performance between the rads is pretty much none
noise will depend on the fans you use, not radiator thickness
personally i think the AX look the best, plus they have a removable shroud, but they will all work fine
Gonna be water cooling my 4771 and 980ti G1 inside the Define S pretty soon. Going with a black / white theme with a midnight blue coolant.
I'm looking at the XSPC rads and was wondering which ones I can go with. Mostly they just differ in thickness, but fin density vaires a bit too. I'm definitely going to run a 240 in the front and 360 rad on top. Which rad should I go with though? The AX? RX? EX?
Thanks guys.
https://linustechtips.com/topic/501103-radiator-questions/
how about the white ones to fit your colour scheme?
https://linustechtips.com/topic/501103-radiator-questions/#findComment-6690777
https://linustechtips.com/topic/501103-radiator-questions/#findComment-6690821
Great! Thanks!
https://linustechtips.com/topic/501103-radiator-questions/#findComment-6690846
